2019-09-10 11:01 PM
2019-09-11 01:16 AM
2019-09-12 08:04 AM
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2019-09-12 08:36 AM
Lingwisyer wrote:The INT version usually comes out first, closely followed by other English language versions.
See this post. It was apparently announced at the launch event.
2019-09-19 05:17 PM
2019-09-20 03:17 AM
2019-09-20 06:15 AM
ejrolon wrote:Thanks! It downloaded and installed just fine.
For some reason, links are active now, so if your key is upgraded then you can use it.
https://www.graphisoft.com/downloads/
2019-09-20 11:06 AM
2019-09-20 11:15 AM
Noémi Balogh
Staff Community Expert, Admin
2019-09-20 11:53 AM
nbalogh wrote:
Hi eschefer,
BIMcloud 2019.3 already supports ARCHICAD 23. You can download it from here: https://www.graphisoft.com/downloads/bimcloud/
BIMcloud Basic supports only one version of ARCHICAD at the same time, so in case you wish to use BIMcloud Basic with ARCHICAD 23, you need to install a new instance.
Kind regards,
