Arc tangent to 2 circles with a specific radius
Drawing tangents are confusing! I need to draw an arc tangent to 2 circles and I want it to be a specific radius. Does Archicad do that?
1 Solution
Lingwisyer
Guru
Just offset your existing two arcs / circles by the radius of your desired arc, then draw your new arc with a centre based on that intersection. AC does not allow you to offset with duplicate a circle, so you will need to duplicated it first before offsetting if you are using one.
Ling.
Go to post
4 Replies 4
No, you will need to work it out geometrically yourself.
It is harder to explain how to work it out than it is to do it.
I am sure it is out there in the world of Google somewhere.
If you don't know how to work it out, let me know and I will try to show you.
Lingwisyer
Guru
Ling.
Eduardo Rolon
This might help, though I have not used it i a long time.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Like this?
Doug
