Arch openings problem
I have a problem using the arch-window opening
The default arch-window use a semi-circle as an arch but this ,if the window is to long,make the window higher than the host wall.
I also try the ellipse window but i have the same problem
Is there an arch-window that use an arch smaller than the semi-circle of the standard window
Thanx
9 REPLIES 9
Do you mean like this, in Door and Window Builder, where the arch is not tangential at the sides?
Yes ,this is ,but a don't have window door builder what can i do???
Miker here is a Screen Shot I had saved for a Different Post back in Dec. 2005. W Eyebrow Fix.
Also Check out this Post, also.
Note: I do not recommend the SE Library.
Thanks for the replies but i want an empty opening and not a window.
Scott Bulmer
Miker,
You most likely already know this, but use SEO for a hole or if you need an empty opening with a frame make a custom window easily done in AC9. Hope that's what you're looking for.
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
If i don't find anything else i 'll do it the easy way.
Thanks anyway
Djordje
Draw the slab of the required shape, set its ID to wallhole, save as a window.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Scott Bulmer
Thanks Djordje; that info is huge!
S
S
Additionaly you can use as ID the "Wallniche"
It cut a piece from a wall not a through out hole
