Arch openings problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2006-03-21
11:20 PM
2023-05-25
06:18 PM
Rubia Torres
The default arch-window use a semi-circle as an arch but this ,if the window is to long,make the window higher than the host wall.
I also try the ellipse window but i have the same problem
Is there an arch-window that use an arch smaller than the semi-circle of the standard window
Thanx
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-22 01:15 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-22 09:16 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-22 11:10 PM
Also Check out this Post, also.
Note: I do not recommend the SE Library.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-23 02:07 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-23 02:59 PM
You most likely already know this, but use SEO for a hole or if you need an empty opening with a frame make a custom window easily done in AC9. Hope that's what you're looking for.
Scott
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-23 06:08 PM
Thanks anyway
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-24 08:07 AM
miker wrote:Draw the slab of the required shape, set its ID to wallhole, save as a window.
Thanks for the replies but i want an empty opening and not a window.
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-24 03:06 PM
Draw the slab of the required shape, set its ID to wallhole, save as a window.Thanks Djordje; that info is huge!
S
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-03-25 12:09 AM
Scott wrote:Additionaly you can use as ID the "Wallniche"
Djordje wrote:Draw the slab of the required shape, set its ID to wallhole, save as a window.Thanks Djordje; that info is huge!
S
It cut a piece from a wall not a through out hole
