ā2011-02-08
12:18 AM
ā2023-05-26
02:33 PM
Rubia Torres
ā2011-06-29 04:46 PM
Peter wrote:
Hi John,
It looks like there needs to be a new adjustable arched top window where the arch extends right through to the inside of the wall, and the infill piece forms part of the frame and is the same thickness. I've attached a real-life example I've encountered in an old farmhouse recently. I presume this is similar to the type of construction you require.
I think it would also be useful to be able to adjust the radius of the top curve on the other arch topped windows too. Not all are semi-circular in reality.
One way you could work around the limitation at the moment is to cut away the incorrect piece of wall above the window with a hidden complex profiled beam SEOed away from the wall, and then manually add in another piece of shaped beam to infill the gap again with the correct materials applied.
ā2013-04-15 04:54 PM
ā2018-10-04 12:52 PM
ā2018-10-05 06:24 AM
ā2018-10-05 09:52 AM
ā2018-10-08 03:24 AM
