ArchiCAD 11 Hotfix (build 1086)
Greg Kmethy
Dear ArchiCAD-Talkers,
We have released Hotfix 1086 for ArchiCAD 11. It applies to Commercial, Trial and Educational licenses, and is currently available for INT and USA language versions. To download the Hotfix, please use "Check for updates..." command in Help menu.
Before installing the Hotfix, please take a moment to read the Release Notes!
Files with hotlinked modules may open unusually slow for the first time, as a result of a critical bugfix. This is normal, and happens at the first opening. After saving such a file, you might notice that the file gets significantly smaller.
A note for Grid Tool users: This Hotfix is a must-have for Grid Tool users. It fixes several functionality bugs, as well as some frequent crashes.
Greg
Gergely Kmethy
42 REPLIES 42
I say thanks to GS for released Hotfix 1086 for ArchiCAD 11
Eddy Rachmat
Papua Barat - Indonesia
Dennis Lee
Thx for the Hotfix - Really appreciate all the responses and hardwork from GS.
Is there any chance that this can be fixed in the next hotfix? I apologize in advance if this puts you in the hot seat...
http://archicad-talk.graphisoft.com/viewtopic.php?t=12141&postdays=0&postorder=asc&highlight=pdf+reference&&start=0
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
Rob
Beautiful, thanks for the Teamwork and Grid Tool bugs fixing... especially Teamwork layout creation fix came handy as we are about to consolidate our layouts scheme.
thanks again...
::rk
Rick Thompson
I went to plot, and my plot preferences were gone? I had to re-setup everything.. which I haven't done in years, so can't remember the details???
Anyone else had this, which I assume is Hotfix related, but unless someone else had it happen, it must be the aliens again.
Hummmm.. same with Environment Schemes. I had recently redone them, and the new scheme has reverted back to the old one. I didn't rename it, but resaved the scheme.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
Dennis Lee
For me, I don't have this problem. Everything working as expected, so far.
Windows 10 x64
Since ArchiCAD 9
Dwight
Archicad can't cope if you move things around. Since some users do not have the plot preference disappearing problem, is it possible you relocated your preferences and put new Archicad in a snit?
Dwight Atkinson
Rick Thompson
Nope, didn't move a thing, just weird is all I can see... but I didn't imagine it. If it's just me and my PPC mac, then it had to have been the aliens.
Rick Thompson
Mac Sonoma AC 26
Dwight
The ones with fire coming from their heads or the grey ones?
Dwight Atkinson
TDabney
I just installed this hotfix as well and noticed a different problem. I used to be able to open more than one session of ArchiCAD to copy/paste between files etc... You could check the box that said "Launch a new instance of ArchiCAD and voila, 2 sessions open. Now when I try to open a second session, I get a WIBU error - No WIBU-KEY driver found. (501) - so I have to open the second session in "evaluation mode". Am I the only one on this?
I'm using AC11 w/just installed hotfix 1086 on an Intel MacBook Pro running 10.4.10
Thanks,
Tom
TND Architects P.L.L.C.
macOS 12.7
2021 16" MacBook Pro
Apple M1 Max
ArchiCAD 26/27
