ArchiCAD 13 shipped on September 14
71 Replies 71
sedley
ejrolon wrote:
Sedley,
Getting the Disk Image will not help since you need to upgrade the Key and that information will be in the box.
I will be able to explore the software, play with the new features etc.
Sedley Jeffers
St.Vincent & the Grenadines
Archicad 26 Full USA - Cadimage & Twinmotion
MacBook Pro M1 16", 64GB RAM. OSX Monterey
David wrote:
Could you explain further? The normal setting for the slab edge is 90˚ (vertical). Any setting between 1˚ - 89˚ cuts the edge back under the slab, any setting between 91˚ - 170˚ moves the cut out the opposite direction from the top of the slab. What sort of result do you expect with a negative number?David
Well that's what I call a hit in the face .
You're absolutely right. No further needs. I didn't interpreted the alpha value as I should : + value = under slab so I wrongly assumed - value for the opposite direction without even thinking about 90+ degrees.
I should stop posting on the forum and concentrate on my projects
Thank you for the clarification
Anybody know why there is not a 30 day trial download for AC 13? Seems like a no brainier to me.
Eduardo Rolon
My guess is that they are waiting until all the subscription users receive their boxes?
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
stefan
At the last event in Belgium, last week on 22 September, the subscription licensees received an EMPTY box and were promised that they'd receive the files later.
Talk about teasers.
Archicad-user since 1998
my Archicad Book
Steve Jepson
I wonder if anyone has received ArchiCAD 13 yet.
Not here yet.
Steve Jepson
Has it even arrived in Boston yet or did they get empty boxes too?
Rakela Raul
from graphisoft or from friends ??
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Steve Jepson
