2009-09-15 02:31 PM
2009-09-25 06:31 PM
ejrolon wrote:I will be able to explore the software, play with the new features etc.
Sedley,
Getting the Disk Image will not help since you need to upgrade the Key and that information will be in the box.
2009-09-25 06:41 PM
David wrote:Well that's what I call a hit in the face
Could you explain further? The normal setting for the slab edge is 90˚ (vertical). Any setting between 1˚ - 89˚ cuts the edge back under the slab, any setting between 91˚ - 170˚ moves the cut out the opposite direction from the top of the slab. What sort of result do you expect with a negative number?David
2009-09-28 03:13 PM
2009-09-28 03:20 PM
another Moderator
2009-09-28 03:27 PM
2009-09-28 07:14 PM
2009-09-28 07:16 PM
Steve wrote:Not here yet.
I wonder if anyone has received ArchiCAD 13 yet.
2009-09-28 07:18 PM
2009-09-28 08:21 PM
I wonder if anyone has received ArchiCAD 13 yetfrom graphisoft or from friends ??
2009-09-28 08:25 PM
