AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
ArchiCAD 16 Hotfix 4 (build 3827) released
We have released Hotfix 4 (build 3827) for ArchiCAD 16.This Hotfix fixes a large number of ArchiCAD 16 bugs. It is also needed for making ArchiCAD 16 CodeMeter license borrowing available again after upgrading CodeMeter keys to AchiCAD 17. The Hotfix is currently available through the automatic update system for INT, USA language versions. Other language versions will be enabled as they pass QC. You can find a list of fixed bugs in the release note:
http://www.graphisoft.com/downloads/archicad/hotfixes/AC16/AC16-3487to3827-ReleaseNotes.html
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
12 Replies 12
Marton Kiss
phubbell wrote:
I am trying to install the hot fix and encounter the following error message.
"ArchiCAD 16 Hotfix #4 cannot access one or more files/folders in Macintosh HD:Applications:Graphisoft:ArchiCAD 16."
This sounds like a permission problem. A few ideas:
- run Disk Utility from Applications, Utilities
- Select the System partition
- Run Verify Permissions then Repair Disk Permissions if indicated
Also select your ArchiCAD 16 folder in Finder:
- right or ctrl click to get the context menu
- get info
- Sharing & Permissions
- make sure your user account has read and write privilege to that folder
- after making changes select the little cogwheel and apply it to all enclosed items
Let us know how it goes,
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
Sightline
Thanks so much for the advice, Marton. I had a similar problem with ArchiCAD 17 hotfix #7 and your detailed post helped me to solve the problem right away!
Diego Torres
Architect-CG Artist
Architectural Concepts and Visualizations
ArchiCAD 4.55 - 24
http://www.sightline3d.com
Marton Kiss
You are quite welcome, I am glad it helped.
Marton Kiss
GRAPHISOFT
