Hi Eduardo,
The ArchiCAD 17 Hotfix 1 (build 3013) was recalled because of this issue:
http://archicadwiki.com/Troubleshooting/WindowPlacement
Today we've released the new Hotfix 1 for USA version as well:
http://www.graphisoft.com/downloads/archicad/hotfixes/AC17/AC17-3002to3013-ReleaseNotes.html
In case you have already updated your ArchiCAD 17 for 3013, change the build number of ArchiCAD to 3002 in the ProductVersion.xml file like this:
<buildnumber>3002</buildnumber>
It enables you to install the new ArchiCAD 17 hotfix 3013 again.
You can find the xml file here:
/Applications/Graphisoft/ArchiCAD 17/ProductVersion.xml
on Mac OS X, or in
Program Files\GRAPHISOFT\ArchiCAD 17\ProductVersion.xml
on Windows.
Please note that the Library Hotfix 1 also needs to be applied.
Katalin Takacs
