2013-05-07 05:18 PM
2013-05-10 09:36 PM
2013-05-10 09:52 PM
Honestly I don't know what will be in ArchiCAD 18.good one !!
2013-05-10 10:58 PM
outpostarc wrote:17 will default open in "Legacy" mode, so everything will be as before until you decide to use the newer way. However, I think most everyone will love the new work flow. It will take getting use to, and a big huge investment to clean up any templates you might rely on, including Favorites. Once done though:) Migrating is a big consideration, but I have 300 ~ 400 plns to eventually migrate and I am not worried at all, not for what I end up with. There is a new feature to delete and replace available fro building materials, composites and layers which help a lot. I am much more excited about this release than any since probably 10.
These global connections are probably a good first step. I would hate to have to manually do every connection each time. However it would be nice to be able to alter an unusual connection graphically.
2013-05-11 12:15 AM
2013-05-11 06:17 AM
laszlonagy wrote:That's OK I am happy with the rendering engines we have anyway, plus we can always get Artlantis if we need to.mthd wrote:I am not dropping hints.laszlonagy wrote:Lazlo, your not dropping hints are you for AC18?
You know, rumours are rumours...
Who knows what part of them is true and to what degree...
AC9 had Light works so AC18 has a new RE in it?
Rumours are Rumours!
2013-05-11 03:35 PM
Bricklyne wrote:I asked the guys at GS and was told that the model was created in ArchiCAD and it was modelled to construction level. Then it was exported to Cinema 4D where the animation was created.
I'm curious as to what "software" was used to make the ArchiCAD 17 PBC Concept Demo video on their website which shows off the new Building Materials and Priority Based Connections in a cutaway section video (with live cutting planes) of assemblies on their Youtube Channel shown below.
https://www.youtube.com/watch?v=2CaZQUywIxY&feature=player_embedded
The practical part of me says that they probably exported the model to Cinema4D (more likely) or Artlantis and did the animation there coordinating the materials through the respective addon.
2013-05-11 05:54 PM
mthd wrote:I expect that 18 is 90%+ specified and probably well underway. 19 is presumably roadmapped and likely largely spec'd and ramping up development now that 17 is wrapping up. AFAIK GS keeps two versions under concurrent development and maps out at least three versions ahead.
What is in 18 is probably not set for a while yet but we hope it is as good as 17.
2013-05-11 09:09 PM
2013-05-11 09:28 PM
laszlonagy wrote:Thanks Laszlo; that's good to know.Bricklyne wrote:I asked the guys at GS and was told that the model was created in ArchiCAD and it was modelled to construction level. Then it was exported to Cinema 4D where the animation was created.
2013-05-11 10:48 PM
