ArchiCAD 17 announced
126 REPLIES 126
laszlonagy wrote:
Steve wrote:
Karl wrote:
OT since two people have asked why we have reference lines: Reference lines are critical; do take the time to understand how they are used and can be used.
The reference line for a wall, for example, "anchors" a space-critical surface of the wall (your choice of what you deem space critical). Frequently, the reference line might be the exterior structural face of a composite or profiled wall. By placing the wall with the reference line there, you can change the entire assembly of the wall and still have the structural, bearing volume of the new structure aligned at that position, all in one step by selecting a new wall type. The exterior skins may grow or shrink. The core(s) may grow or shrink, and the interior finish skins can grow or shrink, but the entire structure will align as intended - e.g., outside face of bearing core to outside face of bearing core below / outside edge of slab below, etc.
Also beware when you are making new composites. There is nothing to indicate which side of your composite the reference line will be on. The reference line of the composite will be at the top of the window where you assemble the materials. Knowing this may save you the trouble of having to reassemble your composites to be consistent with what has been arbitrarily designated as inside or outside in some other place.
Steve, are you talking about ArchiCAD 17 here? Or previous versions.
The reason I am asking is that the whole Reference Line, plus Left/Right/Center method of Wall placement is overhauled in ArchiCAD 17. So you always know what is the Outside and Inside of the structure and it does not change when modifying the Reference Line Location.
Yes. 17. The overhauled method and arbitrary designation of what is Inside/Outside is something that not only works a little different in 17 but also may preclude the way some ( perhaps only me ) were using the Reference Line before. This is not the best thread to get into the details about that. Which is why I was just offering a word of caution.
Having more Lines of Reference ( I would call them ) and tools to manage them, may compromise the ability of the "Reference Line" to proved a single and consistent frame of reference for both spacial and material orientation. The solution I was hoping for would have taken into account the main reason we need a single and always consistent frame of reference in the first place. Openings. It's the language and terms that are being used that needed the over haul. Not the Reference Line.
If you are using terms relative to the Reveal and/or the Reference Line the need for ambiguous terms like Inside/Outside are irrelevant.
This does not mean there would be no need for more "Lines for Reference" in Composites.
Well, let's then just wait for the program to come out so others can try it too. Because this new way is something that should make this whole area less ambiguous so you always know what is inside, outside. It is now basically not dependent on the Reference Line but what you define in the Settings and Composites Dialog. Surfaces (formerly called Materials) are now assigned to the Outside or Inside of a Wall, not to its Reference Line side or side opposite to it.
I personally believe it is more logical now and easier to work with than the old way where you had to watch where your Reference Line is and it the body of the Wall is on its left or right etc.
But we will see what everyone is saying when the version comes out.
That's fair. You are speaking about 17 Reference Lines and Inside/Outside relative to how you and the developers of the new features used or did not use the Reference Line in 16.
If you were using the reference line as I do in 16 your opinion might be different.
Now AC17 has BIMx on board what happens to those who have purchased the VBE and or BIMx full licences in the past before AC17 and also have a current subscription?
Does this mean that those who get AC17 have to pay a fee for each model they publish in BIMx if they do no have a current subscription?
Or what is the point of having a full BIMx Licence now if you have a current subscription?
rocorona
Near the end of the video "027 - Coordinate dimension of libraries" the object is placed with gravity on a Morph. But in the previous images I don't see that option in the Gravity menu. Any idea?
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
David Maudlin
I think they are using the Surface Snap feature to place the object on the Morph.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
JaredBanks
Mentor
I'll add my two cents. ArchiCAD 17 looks to be a killer version. I gave a demo of it to the users in Minnesota earlier this week. Pretty much every question anyone asked about some general ArchiCAD problem was somehow affected by improvements in 17. Not every problem was solved, but so many times I was responding with "well X is improved, fixed, negates that problem... or well in 17 you can now do it this way much easier, etc."
It was nice to see that so many aspects of the program had been tweaked in the new version.
Also... delete an attribute and replace with another attribute (layers too) is a dream function for me.
Plus publish to IFC I imagine is going to make a lot of people very very happy.
Jared Banks, AIA
Shoegnome Architects
The Archicad 17 FAQ gives the release date as 1st June. Is there a timeline for the demo being posted on myarchicad.com ?
Anyone like to hazard a guess based on previous years?
Lennox
There is an introduction webinar on the 18th June so I reckon they will either release the day after or the day before, depending on if they want lots of questions at the end of the webinar.
As I recall from 16 - I could download it just a couple of day before I received the box in the mail. I think that was about 3 weeks after the official release date.
