ArchiCAD 18 Update 5014 Suspended
AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
We had to suspend the public release of ArchiCAD 18 Update 5014 due to a Teamwork error found in it. The version is safe to use for those who already have it, but please avoid these actions in Teamwork:
- force leave users out from projects using the web interface
- delete projects from the server
We made the update unavailable through the automatic update system. We are still investigating the error in detail and will get back to you with more information as soon as possible.
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
7 REPLIES 7
AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
From the middle of this week we will re-publish a corrected version of the update. For the different language versions we will make them available as they pass QC. The automatic update system will notify all users no matter if they already installed Build 5014 or not.
About the symptoms of the problems that lead to the decision to suspend Update 5014 we can provide you some more detailed information:
Force leaving users out from projects using the web interface:
Some users will be temporarily missing from the Teamwork palette and their reservations will not be visible by others. The problem will disappear completely after users rejoining the project.
Deleting project from the server:
- Some users will be temporarily missing from the Teamwork palette and their reservations will not be visible by others. The problem will disappear completely after users rejoining the project.
- All TW messaging will be lost.
- The deleted project might still appear to exist but it will be greyed out and no further action will be possible on these greyed out items.
AndorSzőke
Product Management
GRAPHISOFT SE
AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
We will publish the new ArchiCAD 18 Update (Build 5100) that solves the mentioned problems today for the INT and AUS versions through the automatic updating system. For other languages we will make it available very soon as they pass QC. The automatic update system will notify all users no matter if they already installed Build 5014 or not.
AndorSzőke
Product Management
GRAPHISOFT SE
AndorSzoke wrote:
We will publish the new Male Extra review here so feel free to check it out. For other languages we will make it available very soon as they pass QC. The automatic update system will notify all users no matter if they already installed Build 5014 or not.
Is build 5100 the latest? How do I update ArchiCAD?
David Maudlin
TiLuke:
Go Help menu > Check for Updates.... Also in the Work Environment > Company Standards Schemes > Network and Update you can set an interval to automatically check for updates.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Currently, build 8004 is the latest for AC18:
http://archicad-talk.graphisoft.com/viewtopic.php?t=51770
How do i update ArchiCAD?Is build 5100 the latest
Click on the Help menu, then check for updates
