ArchiCAD 19 Solo Update 4003 is available
AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
We have released ArchiCAD 19 Solo Update 4003. It is currently available through the automatic update system for the INT, UKI language versions. You can download the Update packages from the Release Notes page here:
http://www.graphisoft.com/downloads/archicad/updates/AC19/AC19-3009to4003-SoloReleaseNotes.html
AndorSzőke
Product Management
GRAPHISOFT SE
Follow us on Twitter
GRAPHISOFT HelpCenter - the ArchiCAD knowledge base
9 REPLIES 9
I didn't know there was a difference in INT and UKI versions.
Other versions this month?
AndorSzoke
Graphisoft Alumni
Graphisoft Alumni
Hi Steve,
The Update will be and needs to be available only for these two languages since the Releases of the other two existing Solo language versions (JPN, KOR) already have this build number, so they have the same codebase as the Update.
AndorSzőke
Product Management
GRAPHISOFT SE
DGSketcher
Legend
I'm on AC19 (Full) UKI v3003 still running Yosemite and the Help Menu > "Check for update" says everything is up to date!
I downloaded from the link above, ran the installer and got an advisory "This update has not found a normally installed Archicad to update. ..." with an option to "Browse for ArchiCad and update it".
Do we need to install El Capitan first?
Feeling confused!
vistasp
This is for the SOLO version... the one without teamwork. Won't work for any other.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
DGSketcher
Legend
I thought that was the "Start" version?
When I save my PLN files they are saved as an "ArchiCad Solo Project".
Marketing need to develop greater clarity on these variants...
vistasp
Solo seems to be available only in a couple of countries. It seems to be halfway between Start and Commercial versions.
http://helpcenter.graphisoft.com/technotes/licensing/archicad-license-types/
= v i s t a s p =
bT Square Peg
AndorSzoke wrote:
Hi Steve,
I see. Thanks.
Katalin Borszeki
Yes, I do agree that this is slightly misleading, because of the fact that we do have a SOLO version. We have added this problem to be fixed into our database. Thanks for the catch. K
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
KeesW
What is the 'Solo'version? How is it different from the 'Start' version?
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
