ArchiCAD 9 Hotfix-3 is now available
Greg Kmethy
Dear ArchiCAD-Talkers,
The third hotfix patch (build 2045) for ArchiCAD 9 is now available. Go to the 'Help' menu of ArchiCAD 9 and click on the command 'Check for updates...' This patch can be applied to all previous versions of ArchiCAD 9. For more info please click on the URL below...
http://www.graphisoft.com/support/archicad/
Gergely Kmethy
20 REPLIES 20
Stephen Dolbee
Rakela wrote:
i regret i installd hot fixes
Why?
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Rakela Raul
pm got slower and crashy.....i will do a clean
installation
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
duh...pls help me bout this hot fix....i installed the hot fix.....then i got an error.[protection key is missing or invalid 1050017]that was the message pls help me before they kick me out of my position
If I have a new installation of ArchiCAD, do I need to install all the patches, or just the most recent?
TomWaltz
Just the most recent. They are all bound together.
Tom Waltz
Ok.. Just installed the hotfix and Archicad won't start at all.
Instead, it just gives an error: "The procedure entry point?DisposeCompWallSet@CompWallSet@VBAttr@@SIZPAV12@@Z could not be located in the dynamic link library VBAttributes.DLL"
Can anyone help??? Otherwise will be looking to do a clean install..
starting to regret installing the hotfix also!
TomWaltz
Any time I've installed a hotfix, I've had to do a clean install on it.... so much so that it's almost become habit...
Tom Waltz
Rakela Raul
gs should send a new ac9 cleaned updated copy......and artlantis 'r' is following the same steps
stefan
And what about the promise of "no R2" which was printed on many GS T-shirts?
Archicad-user since 1998
my Archicad Book
TomWaltz
There was no "R2." They are only using build numbers now. 😉
Tom Waltz
