ArchiCAD Competency Challenge
Akos Pfemeter
Dear Archi-Talkers,
Have you ever been in a situation where you were questioned about your level of skill using ArchiCAD, and you have only your own words to rate your abilities? With Graphisoft's recently launched on-line testing resource, now you can measure your ArchiCAD knowledge against an authorized global standard. Please click on the below URL for details of our User Certification Program...
http://www.graphisoft.com/community/certification/
Akos Pfemeter
VP Global Cross-Brand Sales, Graphisoft
82 REPLIES 82
Ben Odonnell
Yes I agree!
This should definitely be a multilingual test. But I think it should be up to all of the respective distributors to fix it. Basically take the existing test and translate it.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobjectĀ®
Akos Pfemeter
We definitely plan to translate the tests to German and in case there is sufficient demand we consider other language translations too...
Akos Pfemeter
Petros Ioannou
Definitely it needs a translation to other languages! Specially questions regarding menu structures... you can handle the meaning of "resize", with a local version but when it goes to "Work Enviroment /..../...." you definitely need next to you the guys who localized the software!
And I found that some questions are quite tricky!
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
stefan
Since the Dutch version doesn't exist anymore, we only have the option of a French or an English version.
I thought I would fail, since I don't use ArchiCAD that often, but it seems that I was at least able to receive 66%.
Some feedback would be nice, e.g. correct the mistakes you made.
Archicad-user since 1998
my Archicad Book
Djordje
IMHO this should be done by local partners, as they are going to do the local testing anyway, and know the language and the lingo better than others. Yes, even english - it takes time to understand that "2 by 4" is not eight ... to quote Gabor Bojar from an old keynote.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I agree, how are we going to learn if we don't know what we got wrong?
__archiben
and i was doing really well this time . . .
(clicked continue after question 50: safari 2.0, tiger)
[edit]could it have been that i changed my location from Australia/SYDNEY to New Zealand/CHRISTCHURCH?[/edit]
b e n _ f r o s t
__archiben
you may also want to look at revising this question from more than a promotional look-ma-no-hands now that spotlight is around . . .
~/archiben
b e n _ f r o s t
James B
Thanks for the link Ben.
Hmm, didn't do as well as I'd thought I would (72%). I'm sure it's ridged against me!
I hate it when I click next and I just realised I made an error, then I hit back, then when I click "next" it skips a number. I suppose so people don't cheat. I hate timers on things, make me make rash decision, again, I'm sure so people don't just load AC and check the answer.
Anyway, nifty bit of fun none the less I'm sure there's a point to this....somewhere....
James Badcock
__archiben
i take it this is a PC only question . . . ?
~/archiben
b e n _ f r o s t
