2007-01-22 08:52 PM
2007-04-25 11:20 AM
2007-04-25 03:06 PM
2007-04-25 03:50 PM
March, wrote:What artistic control have you lost?
On the lack of pmk support I cannot believe the loss of artistic control in layouts now...
2007-04-25 06:54 PM
muttlieb wrote:Bugs in the new versions? Familiarity? Consultants and collaborators using older versions? There's a whole bunch of reason why backward compatibility makes sense and should be a must for any software - and the lack of it typically tends to be an indication of the software company's need to make more money rather than the effeciency and improvements of their new versions.Laura wrote:That's right, you cannot "save as..." to previous versions of Revit. But I don't understand the hesitation to upgrade. Why would you want to turn back?Richard wrote:This is what I've recently heard -- any Revit users out there, please correct me if I'm wrong -- we've got structural consultants
All those old projects in REVIT are "read-only" - once you've opened them in a current version, you'll be in the current version from then on.veryhesitant to upgrade to Revit 8, because there's no turning back...
2007-04-25 07:10 PM
March, wrote:Sounds to me like you have more of a problem with Drawing and Document storage and management in your office ( with regards to having a workflow that allows effecient transfer of drawings and designs from older versions to newer versions) than there is with ArchiCAD 10. Plotmaker and the Pmk format were eliminated ( or rather integrated into ArchiCAD) due to the overwhelming demand by the user base to have a more integrated process and workflow.
This may highlight the difference in understanding between principals responsible for the work & those they rely upon for CAD expertise.
Access to prior projects is important for legal, accumulated efficiency, repeat client retention, artistic & promotional purposes - it is potentially the sweat equity, database, inventory & most valuable asset of a practice beyond the staff resources...
Graphisoft has for what I assume the desire to save a Plotmaker licensing fee traded layout efficacy in the inability to edit in place all past drawing inventory for immediate project workflow efficency.
I cannot express my disappointment strongly enough with this loss of artistic output control at the final stage.
In ArchiCAD 10 I ironically have more artistic output control over an Autodesk drawing than an ArchiCAD one.
2007-04-25 07:30 PM
Bricklyne wrote:Actually, there are very real technical challenges to maintaining backwards compatibility in a parametric 3D modeling program. This topic of backwards compatibility comes up from time to time at the Revit forums, although it doesn't seem to be a very big issue for many users. A while ago one of the Revit founders responded to this topic on the Autodesk Revit Newsgroup and explained in very good detail just why it would be so difficult, and taxing on development resources, to maintain backwards compatibility. Personally, I'd rather have the developers working on new features and enhancementsmuttlieb wrote:Bugs in the new versions? Familiarity? Consultants and collaborators using older versions? There's a whole bunch of reason why backward compatibility makes sense and should be a must for any software - and the lack of it typically tends to be an indication of the software company's need to make more money rather than the effeciency and improvements of their new versions.
2007-04-25 07:39 PM
Bricklyne wrote:Umm... Revit's interface has essentially remained unchanged since I began using the program at version 6.1, and I think it's pretty much the same from 1.0. There is one camp of Revit users that likes the consistency of the UI from release to release, while another segment of users feel Revit is due for a major UI overhaul.
Only be aware that with Autodesk's history, you're not likely to like their way of switching interfaces and workflows from version to version, neither. Ditto legacy access and editing, as has already been mentioned.
2007-04-26 03:54 PM
2007-04-30 02:22 AM
2007-04-30 02:32 AM
refs wrote:
My experience with both:
I have skipped ArchiCAD (and ADT) learned and choose REVIT because of one very important reason: simplicity!
In fact, since 1999, I worked around GIS technology, Bentley parametric technology (Microstation Triforma) and none of them corresponded my expectations. Just Revit!
REVIT principles seat on a well defined strategy which are well apprehended by the user once they start to use the program.
The elements are well structuralized in the following aspects:
- Model Elements;
- View Elements;
- Annotation Elements
Almost all of these elements are represented by "families", easily editable by any user with 3-4 months experience, like me, in contrast with GDL (ArchiCAD) users.
With REVIT, this organization is reflected in their "User Interface" which is quite simple.
I think with ArchiCAD these features aren't clear. Well, at least, I didn't understand them, and their interface it's not straight forward as it has too many icons and options.
With only 3-4 month's experience, using REVIT, I felt I could do things that "Gurus" ArchiCAD users (with eight years experience or more) couldn't do.
Have a look at the link:http://www.revitpt.com/forum/index.php?topic=289.25
(sorry, it's in portuguese)
The virtue is not in the user but in the program, believe it.
We can say that ArchiCAD does almost the same things, but with REVIT it's more intuitive, simpler and easier. I've tested both and I know what I'm talking about.
Another aspect, eventually the most important one: “Parametric Objects”.
With REVIT this is extremely easy with “families”; if I can do it … then everybody can😉
At this moment, I fell I can do things with families that with GDL (ArchiCAD) I couldn't dream of, and I've more experience with ArchiCAD than with REVIT. In the attached file we can see the families and GDL interfaces. Please, compare them …
With REVIT I don't need to script the parametric objects, it just does it (draw it), with easy geometries and parameters … With ArchiCAD it’s like you see …
