ArchiCAD spell checker Crash
Hello everyone
Every time i try to spell check in AC11 (v1114) after 100 or so word checked it stops and then crashes.
Does anyone else have this issue or os it just me.
Thanks
6 REPLIES 6
Djordje
And you would be using Archicad ???? on ????
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
ArchiCAD 11 Version 1114 on PC
The spell checker is part of Microsoft Word on PC's. you get any messages before/after the crash? Verify that MS Word has all updates applied and runs fine?
One of the forum moderators
it starts checking fine.
there is 11500 words to be checked and at around 200 stops and then crash. I am using Word 2007 (could this be a problem?)
Thanks
glad to see this post. I am having the same trouble.
I am also using Word 2007. No error messages. It just stops. Always a the same spot. The @ symbol in this one drawing. It seems to work fine in other drawings.
I get an error regarding my dictionary. I am not sure what it means or how to fix it. Maybe it is related?
In any case, if anyone knows a fix or can explain what's up, I'd like to hear from you.
Hunter.
