2009-04-25
04:37 PM
- last edited on
2023-05-25
05:49 PM
by
Rubia Torres
2009-04-25 05:27 PM
Note: Slab elevation is measured to the top surface of the Slab. By default, this value is set to coincide with the zero level of the current/home story. This means that the elevation of the bottom surface of the slab is obtained by subtracting the thickness from the value shown in the elevation field.This is the same behavior as in AC 11. If you think you have experienced something else, I would take a careful look at your previous settings. I know of no switch or setting to change this (although AC has many such hidden settings ':)')
2009-04-26 02:13 AM
