archislave
Archicad 10 MacTel Beta Feedback
The Beta of the OSX universal release is running fast and stable on a Macbook with 512 mb ram. I would say it is almost equal to the iMac G5 with 1.5 gb ram!
The one thing that puzzles me about the beta is that it seems to have a totally different menu structure and does not seem to have a measure tool. It also did not seem to ship with templates or the default icon strip at the top. I don't know if it is because it is a work in progress or if I a missing something in my installation.
I think it is ready as far as speed and stability go!
Archislave
archicad 26.0 US, M2 Macbook Air
23 Replies 23
Aussie John
~/archiben wrote:
i'd appreciate anyone being able to either confirm whether or not it happens in their setup. i can at least then start looking for the problem in the right places . . . cheers!
~/archiben
Just a list of layouts - no subsets
Masters are at the bottom though
Cheers John
[/size]
__archiben
and all masters are the same size, and none with drawing grids set up . . . ?
do you have an intel archicad to open the same file with . . ?
so do i have a corrupt file, or is there something in the intel file format that is messing with the PPC version of AC?
graphisoft?
~/archiben
b e n _ f r o s t
Aussie John
graphisoft?
~/archiben
Hi Ben
all the Masters are A1 and blank
I only have PPC version of the software and running on G5
Seems to be a bug rather than a corrupt file.
Attached is the bottom half of the layout list
good luck
Cheers John
[/size]
I have identical results to John.
It looks exactly like this. All Nav items gone, layouts remain, generic masters, definitely occurs on opening. Mine is all PPC though.
James Murray
owen
Yep thats what I got ... PPC only here too
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
Ben,
It opens fine on my Mactel machine - hierarchy is intact. My PowerBook has been handed on to my partner so I can't easily test that, but there seems to be plenty of confirmation by others. I'll try it in WinXP when I get to work.
I guess this is why they are calling it a public beta.
Hm. Broken on Mactel for me. (My coworker got one.)
James Murray
Ben, Here's what I did with your file:
1. Open/close on MacBook - view map files/subfiles intact
2. Open above file on G5 - same results as others above.
3A. Close file on G5 without saving, re-open on MacBook - original view map folders/subfolders intact as original.
3B. Save on G5, close, re-open on MacBook - view map is now gone, layout book subfolders gone.
I have repeated this process again with a project originating in AC10 and the view map & layouts remains intact, so this is not a bug for me.
Opening in WinXP on my MacBook Pro - hierarchy is now gone.
Strange stuff, this. I am not having any problems of this sort with any file; whether converted from AC9 or started new. But I have no PPC machines in the mix.
__archiben
ok. i opened the file with the PPC version, lost my layout hierarchies, etc... james, i hadn't realised that my views had gone too because i hadn't 'created' any - but i realise now that placing project indexes meant some views had been automatically generated - they're also missing. maybe this is the same bug?!
so: i faithfully recreated my layout hierarchy from the PPC version of archicad, saved and opened with the mactel. all OK. saved with the mactel and re-opened with the PPC version. all OK. deep. breath.
i have a feeling that the bug is the same, or extremely similar, to james': not caused by the intel<>PPC translation, but by some other trigger. the fact that it opens OK in the intel version probably means that it's a file format bug that they've already got nailed in the intel build . . ? doesn't bode well for multi PPC/intel platform offices if it should happen before the first PPC patch comes out . . .
please can we have some feedback on this, graphisoft?!
~/archiben
b e n _ f r o s t
