Archicad 10 - Removing F1 shortcut key
Hello everybody.
Does anyone know how to remove the shortcut for F1 key (the "help" shortcut).
I've managed to do that by deleting the "help" folder in Archicad's installation directory. But after installing an addon from Cadimage, the shortcut for F1 changed to its initial state. I've uninstalled the addon, deleted all info about it in the registry ... but I can't seem to solve the problem. Hitting the F1 key brings up the annoying help menu.
Could anyone tell me what to do? (maybe editing a registry key that I don't know about, or some settings in Archicad, ...)
Thank you.
Adi Tudoreanu
18 REPLIES 18
Rod wrote:
Or buy a Mac
Easier said than done.
I too was frustrated when I found it was no longer possible to reassign F1 key in AC10. I have been using this key as a shortcut for a long time, because it is closest to my left hand and I am holding the mouse with my right one.
There are many of us who very rarely use Help, so, please, Graphisoft, get rid of this silly fixed shortcut! We are grown-up men and we can decide how to arrange our workspace by ourselves!
There are my of us who very rarely use Help, so, please, Graphisoft, get rid of this silly fixed shortcut! We are grown-up men and we can decide how to arrange our workspace by ourselves!
I totally agree with you. Hopefully they will change that in the near future.
4thorns wrote:
In reflection what he needs to do is get used to not using the Esc key.
Actually the Esc key has a good functionality in ArchiCAD. It escapes more and more of current input/selection steps as it is pressed several times.
It is not a bad feature in my opinion, so it should not be abandoned.
I too was used to using F1 and Ctrl+F1 for shortcuts so this is what I did:
Download a program called Key Tweak from here: http://webpages.charter.net/krumsick/ (Windows 2000/XP)
This program lets you reassign your keys. I reassigned F1 to F9 and vise-versa, then set up my shortcuts in Archicad to work with F9 and Ctrl+F9 now when I hit F1 the computer beleives I hit F9 and everything works as it did before. I still retain F1 help functionality by hitting F9.
Remember to disable the program if you use the Function keys in other programs. Also this would make a really cool April 1st joke, you could really mess around with someones keyboard.
You're right Laz. One of the things I like about it is being able to escape from a command without deselecting all the objects I have selected. Not so in Autocad. I had it in my head that the original post referred to accidentally hitting the F1 key when reaching for the escape key. I'd hit esc a thousand times a day and half of them resulted in the help window...Thus, F1 in the file cabinet!! I still think one should work on the "clicking an empty space" method so as to not have to reactivate a tool every 2 seconds. Doug
I had that problem too. I solved it by "Key Tweak" program. It is problem in Autocad and many programs. Go to Brewer Davidson's adress and download it. It's the best and free solution then you don't have to buy a Mac
Thank you so much Brewer for your tip. It seems it's just what I was looking for.
Adi Tudoreanu
Thank you for the advice. I'll definitely give it a try.
Adi Tudoreanu
