2006-04-26 01:54 PM
2006-05-04 05:50 PM
Bricklyne wrote:So it has nothing to do with add-on. Any object you create, by GDL coding or directly from your plan is clunky for you because it does not behave like a wall.
To illustrate what I mean by clunky;
Suppose I create a Tube, Revolve or Ruled geometry or object in ArchiForma, in lieu of a curved wall with the profiler tool, will I be able to effectively add windows, Doors or openings onto that object the same way I would to a regular wall (i.e based on height from wall-base and centred off the wall axis at a specific distance)? Furthermore will I be able to resize or move those windows, doors and opening the way I would with a regular wall.....................
That's what I mean by clunky.
2006-05-04 10:31 PM
In fact, any object from the library is clunky, because it does not behave like a wall.
Such a lot of clunky stuff, already in AC itself, depressing…
For the simplest things, as you said, regular curved walls are ok for me, whatever window I add.
2006-05-04 10:52 PM
Bricklyne wrote:I agree %100. As strong as ArchiCAD is, I feel this way about many of its tools and objects.
The fact that it may or may not be from the library or GDL coding or some third party add-on is COMPLETELY irrelevant to the fact that I should not have to resort to using it to compensate for ArchiCAD modelling tools' shortcomings.
2006-05-04 11:01 PM
2006-05-05 05:01 AM
Thomas wrote:
Bricklyn, just to over-simplify, misrepresent and essentially denigrate the gist of what you were saying:
- You're telling us all that the new software version which you haven't even seen or tested yourself is just a sh*tload of crap and can't do what you want.
OK.
- You also call us that have seen it essentially liars.
That's your priviledge.
But what I don't understand is what you're doing here? Why not go elsewhere and find something that does what you want? Why keep on using this crap? What's the upside, for you?
2006-05-05 05:05 AM
2006-05-05 05:52 AM
2006-05-05 06:18 AM
2006-05-05 08:51 AM
All right guys, break it up.Sorry guys. Couldn't resist it.
2006-05-05 08:53 AM
Bricklyne wrote:I might have over simplified your point but it is exactly what you summarized. What you do not like is the fact that SOMETIMES, AC asks you to use another object (TUBE, EXTRUDE…) than XWALL to
