Archicad 24 Update 2 released
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear All,
On Monday, we started the release of Archicad 24 Update 2 (build 4007)!
The Archicad 24 Update 2 is the first update that provides — among other enhancements — an improved Integrated Design workflow and Issue Management introduced with Archicad 24 in July. This update also includes the usual quality and stability improvements.
You may read the List of Improvements here, while the update installers are available on the Support > Downloads section of our website.
We prepared some YouTube video playlists and Help Center articles for Archicad 24 Update 2. Please have a look with the links below:
Should you have any questions or feedback, please let me know!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
17 REPLIES 17
Eduardo Rolon
…and now I get this issue almost daily on wake from sleep. Only a restart fixes it.
No issues either during the Beta or all 24 releases up to Update 2.
Eduardo RolĂłn AIA NCARB
AC29 US/INT -> AC08
another Moderator
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi Eduardo,
Thanks for the report and I am very sorry about the issue!
Does this issue ever happen to you before? This seems to be a graphics card driver issue. Unfortunately, Apple is very strict in distributing drivers through OS update, so if that's the case, we won't be able to change anything. One thing I can suggest is to turn off 2D Hardware Acceleration (Options > Work Environment > Advanced Redraw Options). It might help with the green stripes, but in return, the performance may suffer.
Please let me know how it goes!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
Bug inside level tool zone
When we choose to place the level inside the zone tool, even if we set it to update automatically, it is always zero. Is it a bug?
I don't think so. Level dimensions don't respond to zones. Only Roof, Shell, Slab, Mesh, and stairs/landings.
Richard
AC26 (since AC6.0), Win10
RandyC
Will there be a US version or should one load the international update ?
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
There already is a US version, which is the one you should download if you're in the US. The easiest way is to "Check for updates" in the Help menu.
Richard
RandyC
check for updates says I have the latest 3007
Guess I will have to find it manually
rm
Is Graphisoft endorsing use of Apples Big Sur with this latest AC release?
Robert Mariani
MARIANI design studio, PLLC
Architecture / Architectural Photography
www.robertmariani.com
Mac OSX 13.1
AC 24 / 25 / 26
Eduardo Rolon
FWIW, Green screen issues have disappeared.
AC29 US/INT -> AC08
another Moderator
