2020-10-06 12:16 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-10-08 11:05 AM
2020-10-16 01:22 AM
2020-10-16 09:01 AM
Carlos wrote:Hi Carlos,
Hi all,
we just installed the update a couple of days ago hoping it would solve some sporadic crashes we were suffering, but I would say that it just got worst! Is someone else experiencing this? I hope it will be solved soon with a future update!
We are working using MacOS Catalina 10.15.7 and with projects on BIMserver
Any suggestions are welcome!
Thanks
Carlos
Minh Nguyen
GRAPHISOFT
2020-10-16 02:00 PM
2020-10-22 12:56 AM
2020-10-22 06:14 PM
2020-11-09 11:42 AM
2020-11-10 09:09 AM
Hi Minh,
I would like to give you some more feedback:
while we wait for version 4000 to be released as a regular update we are still working on 3022 and still experiencing crashes, nothing new there.
What I want to report is related to the recovery of files after a crash:
I have been always very pleased on how good is Archicad at recovering information after a crash, but recently we are having issues: we are working as a team in BIMcloud and quite often after a crash everything gets lost, we have encountered two scenarios: after a crash we are able to open the recovered file but everything that was changed since the latest "send and received" is gone...I guess we should send and receive more often but there must be another way, we have our settings as "ultra safe" but it doesn't seem to help.
The other scenario is worst: after a crash if we try to open the file archicad says that it is corrupted and it is not possible to open it, the only way forward is to delete the user from that project in the bimserver and rejoin the project.
The aim of this post is just to make you aware of issues that could be improved. Looking forward to the final version of 4000 that hopefully will make our life much easier.
Regards,
Carlos
Minh Nguyen
GRAPHISOFT
2020-12-01 07:03 PM
2020-12-01 07:19 PM
Jeff wrote:Hi Jeff,
I can't seem to access the 3022 update for version 24. When I go online to support and download the latest version it always downloads build version 3008. When I select 'about archicad' it says I'm on build 3008. I used to be able to see multiple build versions on the website but it appears to have been reformatted and that is no longer an option?
When I select 'check for updates' it only tells me my Revit Exchange is out of date, and doesn't even mention that there is an update for archicad itself. What's the deal? We have a doze FULL copies of the software.
