Archicad [Demo Mode] has no Copy function
AlOICE
In the upper left corner of your screenshot, I can see the text "...are disabled".
This is what is displayed when you are running Archicad in DEMO mode. As the message says, in DEMO mode, "Save, copy, and Teamwork functions are disabled." This is why you do not have the Copy command available.
furtonb
It certainly does:
Maybe try and reset your Work Environment by applying one of the default ones?
odv.hu | actively using: AC25-27 INT | Rhino6-8 | macOS @ apple silicon / win10 x64
Lingwisyer
Guru
Or just use Ctrl / Cmd + C
