Archicad ground plan hatches
Is it possible in archicad when I am watching the ground plan in 2D view to choose more hatches, instead of only 2 options that the software provides, like it happens in autocad?
Thanks
There are about 60 predefined fills (hatches) in Archicad. And can make your own as many as you wish.
Is it enough?
lambis wrote:
Thanks
If you do not have hatches in your file, you can do a New & Reset commans to start a new Project. A new Project will have all Fill patterns (Hatches in Autocadese) available.
Or, you can import Fills from another ArchiCAD Project using the Attribute Manager Dialog.
