Are there plans to incorporate Reflected Ceilings in AC ?
I mean a true reflected ceiling plan where it would appear like your were actually looking up at the modeled ceiling (instead of now where your RCP's in Archicad are actually looking down on the ceiling). Maybe this functionality already exists by tweaking the cut plane settings......any suggestions?
14 REPLIES 14
TomWaltz
It would be really nice, but no
Tom Waltz
Rakela Raul
there r a couple of addons for that but we use a patterned slab...\
there is also a ceiling accessory in ac
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
Bruce
My understanding was that this is the drafting convention. Do you mean that the entire plan, including building envelope, would be flipped?
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
TomWaltz
The plans would still read in the same orientation, but with the floor plan cutting plane seeing upward instead of downward, removing the weird display order issues on slabs that show a ceiling and allowing elements that are "dashed above" on the plan to read solid.
Some people even include roof overhangs and soffits on them.
Tom Waltz
Use your 3d cutting plane.
Save the view you want of the ceiling and place it into the Layout on top of the reflected ceiling plan.
Can work for making projected or reflected ceiling plans.
TomWaltz
... except 3D cutting plane does not affect the display order of slabs, does it?
Tom Waltz
Everything you want to change about the display order of slabs can be done in the view you make in model space.
Make the 3d cutaway view you place over it show only the ceiling.
The 3d cutting plan drawing over the reflected one is a nice idea, but how do you solve the problem of dashed contour walls of the floor above?
I usually redraw the complete floorplan with lines and sectioned fills for the structural plans. Is there a better solution? I wish ghost view could be saved and hotlinked with dashed lines...
Zoltán
You can make a view show anyway you want in model space. You can use a different cut plane individual views if needed. Then place that view on top the other drawings in Layout. This is how you can have a ghost story in layout. It may also be useful to use a different pen set for some of these drawings.
