2021-09-30 08:07 AM
Does anyone know which library this object belongs to? And how I can procure it?
2021-09-30 09:01 AM - edited 2021-09-30 09:14 AM
Difficult to figure out by "Residential window" name only. Could you attach a picture or better description?
Maybe it belongs to the ssa AUS essential library?
| Archicad 4.55 - 27
2021-09-30 09:05 AM
From the CI Essential Library? If you have a SSA you should be able to log into the MYCI portal and download the library from there.
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2021-10-04 04:35 AM
Thanks - per your suggestions, I think that is correct, it's part of the Aus Essential/MYCI library.
I don't currently have an SSA so will need to upgrade... 😞
2021-10-04 05:51 AM
Is there some feature of this window that you need that you cannot achieve with the default windows?
2021-10-04 06:21 AM
The ability to have a header material above the window that is different to the wall is the critial element.
