‎2007-06-09
12:52 AM
‎2023-05-23
05:08 PM
Rubia Torres
‎2007-06-09 01:25 AM
‎2007-06-09 07:06 AM
‎2007-06-09 07:41 AM
‎2007-06-09 08:18 AM
‎2007-06-09 09:25 AM
‎2007-06-10 11:57 AM
‎2007-06-10 01:43 PM
David wrote:If it were that simple...
Best you always used to use pen 91 Thomas....
‎2007-06-11 12:50 PM
‎2007-06-11 02:14 PM
DrawingStudio wrote:No, you need to open each part in the library editor, change the default, and resave with a new name.
So I'd have to go through each individual library part and do a 'Save Selection As...'
Who really wants fills on objects anyway and why has Graphisoft picked a specific one for us?The problem is that the parts are looking for their cover fill by index number. It is quite common for these numbers to get jumbled and the wrong pattern comes up in the library parts. The simplest fix is to determine the index number of the fill that is being used and use Attribute Manager to replace it with the correct one. It is probably fill #85 "Empty Fill" that you need. If you are using the fill that is being replaced for other things you can reinstall it at with different index and the same name. Attribute Manager can be a little tricky (and frustrating at times) so practice on a copy of the project until your comfortable with it.
I hope they change it to a generic 'empty fill' in the future. Topic for a poll?There have been many requests along the line. Something definitely needs to be done to fix this problem in particular and the index number problems in general.
