Gus
Automatic Wall Thickness Dimensions Not Desired
Every time I dimension to a wall it automatically creates a dimension string including the wall thickness. I almost never want to dimension a wall thickness so I wish this would stop. Every single time I dimension to a wall I have to then delete that wall thickness part which is really annoying. Is there any way to turn this automatic feature off?
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
5 Replies 5
If you place the cursor to the very end or internal corner it wont do both sides.
Yes, what Roger is suggesting: you have to find a Wall node, not a Wall edge.
You can do that if you dimension manually, but not with automatic dimensioning.
Gus
That Helps thanks
Madison WI
Link
This is a long-standing wish! I think it'd be great if we had the choice of selecting the left side of the wall, the right side, or the reference line.
Link.
