Autoselect when undo-redo disabled in ArhiCAD 16
Hello,
I use the trick with undo-redo to select things i've drawn the last few steps. Like drawing 5 lines then undo 5 times then redo 5 times and you select all in less than 1 sec. In AC16 that autoselect feature is disabled. How can I reactivate it? It works on AC17, but I need some time to move to the new composite thing...
Thank you very much for your time!
P.S. I got it working when I use the selection type Subelem, but this way you can't touch anything but shell and morph, so it's useless solution...
0 Replies 0
