BUG with Attribute manager in AC 9
I guess i found a bug with attribute manager in AC9: Textures attached to materials don´t come anymore, just the hatching and the material itself. Worked fine in AC 8.1.
Can anyone please confirm this?
Thanks,
Ricardo
5 REPLIES 5
Link
Confirmed.
Please let your reseller know ASAP!
Link.
I have had no problem, but I have only moved one real project into 9 so far. I also opened real projects in the beta without problems.
What are the circumstances when this occurs?
Or does it happen all the time for you?
Ted Taylor
I have had same problem. What platform are you on?
Ted Taylor
Atlanta, GA , USA
iMac (Retina 5K, 27", Late 2015)
3.3 GHz Intel Core i5 32GB
AMD Radeon R9 M395 2GB
OS10.14.2,
Latest Archicad 22
Greg Kmethy
This is unfortunately true, but for PLN only. If you use an .aat file to transfer attributes, you will save the textures.
Gergely Kmethy
I'm glad to hear about the problem and even the work around before I even ran into it myself. Thanks all.
