2007-08-01 10:07 AM
2007-08-03 08:33 AM
Piotr wrote:I am not sure what you are talking about but we do not have our old keys anymore. When the reseller gave us the new key (I do not remember which version), we had to give back the old one.Philippe wrote:If You have the 7.0 CD You could actuallly find a 6.5 working with WIBU there...so no need to be on the dark side
I did not install AC11 yet but the documentation says you can use the dongle back to 7.0 installation.
Actually, we have kept a 6.5 "open source"version, which allows us to get our oldest projects (5). I think GS could distribute a free AC 6.5 CD, so we do not have to use the dark side
way…Who's going to professionally use a 6 years old soft?
Best Regards,
Piotr
2007-08-03 11:51 AM
Philippe wrote:If I remember correctly - there was a special compatibility folder on 7.0 CD where there were updates to the original 6.5 with the WIBU keys compatibility - If You are on the PC I will check up the CD later at home as I have the old boxes there
2007-08-03 12:05 PM
Piotr wrote:Well might be useful for some others. In our office, we'll keep on using 9 and 6.5Philippe wrote:If I remember correctly - there was a special compatibility folder on 7.0 CD where there were updates to the original 6.5 with the WIBU keys compatibility - If You are on the PC I will check up the CD later at home as I have the old boxes there
I am not sure what you are talking about but we do not have our old keys anymore. When the reseller gave us the new key (I do not remember which version), we had to give back the old one.😉
Best Regards,
Piotr
2007-08-03 02:56 PM
2007-08-03 03:07 PM
2007-08-03 03:29 PM
TomWaltz wrote:Yeah, this is an idea for a future business!
At some point, it's cheaper to hire someone at minimum wage to update them all then to keep the old versions around (presumably on old machines they can even run on)
2007-08-03 04:26 PM
another Moderator
2007-08-03 05:16 PM
2007-08-03 09:17 PM
Philippe wrote:OK I just checked the regular 7.0 and the famous "Silver Bullet" - and on both there is a "Support" directory with 3 subfolders "AC60", "AC65", "AC70" the first two contain the filest that should be used for replacing the original files inside the folders where 6.0 or 6.5 were installed - the last "AC70" contain the copyt060.apx - and it is self explanatory...
Well might be useful for some others. In our office, we'll keep on using 9 and 6.5only; it makes the full bridge for all our files.
2007-08-05 01:47 PM
