Backwards Compatibilty
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2007-08-01 10:07 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-08-03 08:33 AM
Piotr wrote:I am not sure what you are talking about but we do not have our old keys anymore. When the reseller gave us the new key (I do not remember which version), we had to give back the old one.Philippe wrote:If You have the 7.0 CD You could actuallly find a 6.5 working with WIBU there...so no need to be on the dark side
I did not install AC11 yet but the documentation says you can use the dongle back to 7.0 installation.
Actually, we have kept a 6.5 "open source"version, which allows us to get our oldest projects (5). I think GS could distribute a free AC 6.5 CD, so we do not have to use the dark side
way…Who's going to professionally use a 6 years old soft?
Best Regards,
Piotr
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-08-03 11:51 AM
Philippe wrote:If I remember correctly - there was a special compatibility folder on 7.0 CD where there were updates to the original 6.5 with the WIBU keys compatibility - If You are on the PC I will check up the CD later at home as I have the old boxes there
Best Regards,
Piotr
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-08-03 12:05 PM
Piotr wrote:Well might be useful for some others. In our office, we'll keep on using 9 and 6.5Philippe wrote:If I remember correctly - there was a special compatibility folder on 7.0 CD where there were updates to the original 6.5 with the WIBU keys compatibility - If You are on the PC I will check up the CD later at home as I have the old boxes there
I am not sure what you are talking about but we do not have our old keys anymore. When the reseller gave us the new key (I do not remember which version), we had to give back the old one.😉
Best Regards,
Piotr
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-08-03 02:56 PM
Many of these projects are very important to me, I often go back to use them as am example for my current work. For instance - how often do you design an indoor swimming-pool facility? I have once! And if I have to do it again, I want to have a look at this project!
By the way, for AutoCAD there are applications which transform its files to ANY version backward and forward!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-08-03 03:07 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-08-03 03:29 PM
TomWaltz wrote:Yeah, this is an idea for a future business!
At some point, it's cheaper to hire someone at minimum wage to update them all then to keep the old versions around (presumably on old machines they can even run on)
I can imagine the slogan on the web-site:
Send us your old projects and get them back as new!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-08-03 04:26 PM
For I have Win2k as a VM running in Parallels in one of my Macs for running Autocad 2006 when I need it, in theory I could install AC07 to keep up to date.
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-08-03 05:16 PM
Petros
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-08-03 09:17 PM
Philippe wrote:OK I just checked the regular 7.0 and the famous "Silver Bullet" - and on both there is a "Support" directory with 3 subfolders "AC60", "AC65", "AC70" the first two contain the filest that should be used for replacing the original files inside the folders where 6.0 or 6.5 were installed - the last "AC70" contain the copyt060.apx - and it is self explanatory...
Well might be useful for some others. In our office, we'll keep on using 9 and 6.5only; it makes the full bridge for all our files.
So it seems the oldest version that can be run on WIBU key is the 6.0
Best Regards,
Piotr
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-08-05 01:47 PM
It might be worth to use a non-legal old copy, to avoid dongle incompatibilties... but that's clearly beyond being supported!
The advantage of old copies in Virtual PC (which is currently free, by the way) is that you can keep them running in an old environment (old Office, old OS, old drivers etc...) and can reset them are discard the undo-disk, so you can always get into an "clean" basic installation.
Archicad28/Revit2024/Rhino8/Solibri/Zoom
Archicad-user since 1998
my Archicad Book
