2008-05-24 01:25 PM
2008-05-24 06:58 PM
2008-05-25 12:09 AM
2008-05-27 06:50 PM
Erich wrote:Correct. Forget the lines.
You may also want to check out Oliver Dentan's insulation object found on his web site at:
http://pagesperso-orange.fr/archilib.od/index.html
The benefit is that he has written the object w/ graphical hotspots that allow you to trim the ends of the insulation to match conditions such as would be seen in a typical eave. You can also graphically adjust the thickness, and the loop size.
Very useful.
