2009-04-20
10:44 PM
2025-07-22
12:06 PM
Aruzhan Ilaikova
2009-04-22 06:52 PM
2009-04-22 06:54 PM
2009-04-22 07:25 PM
Karl wrote:I always knew you were smart but telepathic Karl? No sig, no links .. how do you find this info??
If the web site is true correct that your firm has over 400 employees..
2009-04-22 07:47 PM
2009-04-22 10:23 PM
iver7044 wrote:Man, sometimes I simply think we're too kind and helpful here. If a professional architect is too lazy to even take a look at the help files of his bread-and-butter program, not mentioning check the Reference Guide that's installed with the program (also in the Help menu), why should
Thank you for explaining that w/ the profile editor. That works, but seems to be too much work.
I could use the library, but why is there a beam tool if you can't use AISC standard beams? That seems to be negating the purpose of the beam and column tool. I don't want to have to go into the library every time to find the beam I want. Why isn't there a pull down menu from the Beam and column command for standard steel sizes?
2009-04-22 10:39 PM
iver7044 wrote:Without repeating the "get some training" thing...oops, I guess I just repeated it...
2009-04-22 10:48 PM
2009-04-22 10:50 PM
iver7044 wrote:So why should we bother to help you?
Why should I get training. I hardly use archicad at all. I just need to use if for one project.
2009-04-23 08:52 AM
Karl wrote:Karl aka 'Big Brother'
Moderators have access to a bit of hidden info about users here...
2009-04-23 10:30 AM
