Beams cut in section
ares997
Is there a way to only cut through a beam or any object in section even though the depth of the section is set to a predefined distance? In this image I have beams that I only want to show the cut through the beam and nothing else. Is that possible?
Thanks.
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
4 REPLIES 4
Layers?
ares997
I want the beam flanges in the distance to disappear and keep the section "live." Is that possible?
Dwight
mask?
Dwight Atkinson
David Maudlin
The Floor Plan and Section > Outlines > Uncut Line Pen controls the pen seen in Sect/Elev/3D, so if you can change this pen to white, the beam will disappear in section where it is not cut.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
