Bevel wall edges?
Hello, is it possible to bevel corner edges on walls, so that they are not 90 degrees sharp but a little bit round?
13 Replies 13
Alright.. thank you both, i have managed to to do it now. Thank you for your time.
One question more .. is it possible to change the window/door holes as well?
I would recommend using custom profile column or separate polygonal wall to only fill the inside of the corner if composite wall is used but unfortunately it wouldn't clean up in 2D. The complex profile column doesn't intersect with walls as traditional column would. With outside corner the SEO with hidden layer element would be the best way IMO.
Something like Custom reveal? Custom reveal itself is quite limited but you can edit polygonal wall near the door or the window.
