‎2009-09-04 12:01 PM
‎2009-09-09 01:56 PM
GeNOS wrote:Just a few off the top of my head:
yeah i realise that i can work in colour and print in black and white with the same pen weights. just never seen the need to draft using colour.. tho i do like the idea of LIVE and FIXED dims being different colours.. but still other then that i cant see any need for colors??
‎2009-09-09 02:05 PM
Karl wrote:Karl:
What do you mean by fixed and live dimensions?
I thought that Dimensions were always live, so if something was adjusted, the dimension was updated?
‎2009-09-09 04:51 PM
GeNOS wrote:I like to use lots of dims that I don't want to see in the prints. I make these smaller and a different color. It is also useful when you use the Find and Select tool.
‎2009-09-09 07:06 PM
‎2009-09-09 07:09 PM
Steve wrote:What kind of dimensions do you place but don't want to print?
‎2009-09-09 08:34 PM
Erika wrote:things like finish dimensions. I only want dimensions to face of stud in the prints. Also to dimensions of objects in the room, dimensions that I need to know in order to accurately place something that is dimensioned. I usually dimension my light fixture layouts to make sure I am not hitting a ceiling joist or something, but I don't want to see those dimensions on my electrical plan. I use discriptors like "4 equal spaces, center line, EQ 5 typ., things like that rather than dimensions. Sometimes I add a dimension just to give myself a center point node point I can use to place something.
What kind of dimensions do you place but don't want to print? ...
‎2009-09-10 03:25 AM
David wrote:i dont really have a need for any of that, i just seem to know whats what cos i did it/put it there.. i guess it would be helpful if more then one person was working on the jobs?. but i cant see any need for any of that for myself (personally)GeNOS wrote:Just a few off the top of my head:
1. To distinguish line weights, even when zoomed out or with only hairlines shown.
2. To distinguish the type of element (for example: slab vs. roof) in 2D and 3D.
3. To distinguish the layer of element.
This all assumes standards have been established and adhered to during the course of the project, but having done that, I cannot imagine using ArchiCAD without color, it just seems crippling.
‎2009-09-10 07:34 AM
GeNOS wrote:"ditto". White fills and lines can be hard to find sometimes on the other hand when they are placed for masking purposes at least you are seeing the drawing as it will be printed with the fill hiding what you want to hide.
i use a white back ground and everything (all my pens) is set to black (no colors).. for that reason i use white back ground.. my plans are printed in black and white so i see no need to draft plans in anything but
‎2009-09-14 08:35 PM
‎2009-09-15 12:29 AM
Steven wrote:all my elements are set up with he correct line weights for out lines, cut lines etc.. so i shoudlnt need to change anything cos AC will sort the weights out for me....
I work with color strictly, I cannot imagine working with black only. My main reason is to distinguish lineweights. We've memorized the lineweights by color. You know immediately by looking at the screen what lineweight something is and if it needs to be changed.
