JohnJay
Bug? COver fill override doesn't work with Morphs
1. Create a slab and assign a cover fill
2. Duplicate the slab
3. Convert one of the slabs to a Morph
The 2 objects should look the same but one is a Slab and the other a Morph
4. Create a Graphic Override Combination - applicable to 'All Types' with 'Cover Fill' as specified in 1. (above)
5. Override should change hatch to any other
The override works fine with the slab but doesn't change the Morph cover fill
AC27 | i7990x | RTX4070 | W10
I can confirm this does not work, but I don't know why (tried in 22 and 26).
If you change the criteria so it does not include the fill (i.e. just all types), it does work.
But as soon as you want to override a particular fill it does not override the morph.
I would report this to your local Archicad support to see what they say.
If it is a bug, they can pass it on to GS HQ.
JohnJay
Thanks
Will report as suggested
