Building Material Intersection Problem
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-12-10
03:45 PM
- last edited on
2023-05-23
02:07 PM
by
Rubia Torres
2019-12-10
03:45 PM
1. The layer priorities are all the same.
2. The building material intersection priorities are all set correctly. For example, the block is a higher priority than the wood stud wall above it and the GWB. They should not be showing.
3. They are all on the same renovation filter.
What am I missing? This should all heal up correctly. When I move the wood wall onto the concrete slab, the priorities work.
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-12-10 04:13 PM
2019-12-10
04:13 PM
Two things:
1. Walls do not automatically intersect with other vertically overlapping Walls. To solve this situation I would suggest you define a Complex Profile Wall with Parametric Wall Skin heights so you can adjust the vertical heights of your Wall skins manually after placement. The other option is to use SEO to subtract the body of the lower Wall from the upper Wall.
2. Wall-Roof Connections are not automatic either, you have to use the "Trim Elements to Roof/Shell" command.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-12-10 04:45 PM
2019-12-10
04:45 PM
Thanks Laszlo. Do you know the reasoning behind not allowing wall intersections?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-12-11 05:18 PM
2019-12-11
05:18 PM
No, not really. I guess it was just never implemented.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-12-11 11:27 PM
2019-12-11
11:27 PM
I remember reading somewhere in the help guidance that for PBCs to work the baseline / planes need to intersect. Much like wall intersections on plan, you need to have a floor slab connect with the wall baseline.
There are several pages on the subject here... https://helpcenter.graphisoft.com/user-guide/76665/
