‎2021-06-02
11:29 PM
‎2023-05-09
03:43 PM
Rubia Torres
Solved! Go to Solution.
‎2021-06-04 03:46 AM
‎2021-06-03 03:59 AM
‎2021-06-03 11:23 AM
‎2021-06-03 04:20 PM
‎2021-06-03 06:14 PM
‎2021-06-08 05:14 PM
‎2021-06-09 09:26 AM
‎2022-02-11 03:06 AM
I've often wondered, what did the folks at Graphisoft have in mind when they assigned the various priorities to Plywood, Underlayment, Subflooring, Wood Sheathing, and OSB? Were there particular applications each was intended for? Aside from Subflooring it doesn't seem obvious which to use on exterior walls vs roofs for example. Plus, contractors I work with sometimes use the terms Underlayment and Sheathing interchangeably.
‎2022-02-15 08:48 AM
In our template we generally have 'structural' and 'finish' versions of the same materials.
Some projects require some extra 'custom' variations.
