10 hours ago
I've recently added in a few new building materials and assigned them to the wall composites.
My goal now is to have the 2D / GA plan show minimal detail, just a solid colour instead of a hatch. Current view after the building material changes:
Before this change, the walls used to look like this (ignore the thicker lines, this is a screenshot from an exported drawing):
Any way I can achieve this without having to simplify my building materials or wall composites?
Operating system used: Windows 10
10 hours ago
You might want to look into graphic overrides - you can override the cut fill and cut fill pens as you wish and save it without affecting the original drawing.
https://help.graphisoft.com/AC/24/int/_AC24_Help/050_ViewsVB/050_ViewsVB-134.htm
9 hours ago
I've tried that and it somewhat works but it only appears to allow me to set one colour for the entire wall, it cannot have multiple. I tried to create 3 separate rules, 1 for plasterboard, 1 for timber frame and 1 for insulation all with different colours but the graphic override only takes the colour of 1 of them into account at a time.
9 hours ago
It should be able to do your intended overrides. Can you maybe share one of the rules you made?
8 hours ago
This is one of the rules, and below you have all 3 rules. You can see the different colours set as examples; in this configuration, walls are pale orange, ignoring the green and black overrides.
8 hours ago
Thank you!
I tried to replicate your situation and I'm facing the same issues:
After some searching I have found this wishlist item, and apparently this is not a current feature, and has been requested previously: https://community.graphisoft.com/t5/Visualization/Feature-request-Graphic-Override-for-building-mate...
8 hours ago
That's really disappointing and defeats the purpose of the building materials... Thanks for your time in trying to help find a solution.
6 hours ago
You can opt to only override the fills and not the colours
5 hours ago - last edited 5 hours ago
Sorry deleted.
