COMPOSITE WALL END LINE NOT SHOWING CORRECT LINE WEIGHT
Bling Keeta
I have set both for wall end lines.
Cannot edit wall end line pen.
Ben Ling
B.L.LING ARCHITECT INC.
Vancouver, BC, Canada
Mac Pro 3.5 GHz 6-Core Intel Xeon E5
AC 20
5 REPLIES 5
David Maudlin
Ben:
Two things to check:
1. In the Composite Structures > for each Fill > Use Skin End Lines
2. In the Wall Settings > Floor Plan and Section > Cut Surfaces > Cut Line Pen > Apply Structure's Settings
If these don't work, post screen shots of the Composite Structures and Wall Settings > Floor Plan and Section dialog boxes.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Bling Keeta
Thank you for trying to help.
But I couldn't find "use skin end lines" in Composite Structures,
and "Apply structures settings" in Wall Settings.
If you look at the pictures of the 2 wall ends, one shows a faint wall end (when I activate show "both" ends in Wall Settings, and the other shows nothing when I deactivate wall ends.
Thanks again .
Ben Ling
AC 20
Bling Keeta
Here's additional attachments.
Thanks.
Ben Ling
AC 20
Bling Keeta
I found them. Thanks for the hint David.
Ben Ling
AC 20
David Maudlin
Ben:
Glad you figured it out.
For others finding this thread, my answer was for AC16 and earlier, for AC17 see in the Help files: User Interface Reference > Dialog Boxes > Composite Structures Dialog Box > Skin End Lines.
David
