CURVED SECTIONS
Maybe this is dump question but is it possible to make curved section in archicad 12
8 REPLIES 8
I'm afraid not. Curved sections are not even available in AC13. You could try creating several short individual sections and join them back together on a layout. It's not really curved, but it's the best we can do.
Gerald Hoffman
You can make a curved 3D section view but I think you are looking for a 2D section cut.
Gerald
"The simplification of anything is always sensational" GKC
AC 25-4013 USA, CadImage Tools
2019 MacBook Pro 16" w/ AMD Radeon Pro 5600M GPU
OS X 11.6
2.4 Ghz 8 core i9, 64 GB RAM
27" LG 5K Monitor
Eduardo Rolon
If you can see it in the 3D window you can save it as a 3D Document. The only thing to configure is the 3D View Settings to see the model in elevation.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
How did you to the 3d curved section?
I knew for this 3d curved secion, but I was looking for 2d section plan... Never mind, I'll try with several shorter sections and with matching them. Anyway thanks for helping...
Dwight
A circular marquee is made by magic wanding a circle.
Dwight Atkinson
😉 sounds good thanks
Dwight
In fact, even a magic wanded marquee will follow even a negative/void edge in Archicad 13, where some prior editions did a shortcut.
Dwight Atkinson
