Cabinet thickness
Hi! I'm a novice user of Archi13 and quite new to this forum.
Any one knows how to change the thickness of a kitchen cabinet from 20mm to a different value? I found an option to change door thickness but not for the body itself. Help please.
Ta!
1 REPLY 1
David Maudlin
Ging1:
Based on a quick look at one of the cabinets in ArchiCAD 15 (Cabinet Base 1D 15), this value (0.02) is hard coded into a macro used for the cabinet body. So there is no way to change this value parametrically, you would need to use GDL to alter the value in the macro, which could lead to other problems with any object that also uses this macro (fa_gen_basecabinet). Short answer: not easily.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
