ā2004-10-17 11:59 PM
ā2004-10-18 12:25 AM
ā2004-10-18 11:32 PM
ā2004-10-22 04:21 AM
Is there any way to generate the scene in 3d window rather than photorealistic to save time, then generate again later in photor?No mate! Once it created, it's created! And that's through the photorendering engine only!
Also, when I generate the scene, it is rotated 90 degrees in the PR window. The bottom of the building is parallel to the right side of the screen.The reason for this is because it is faster for the rendering engine to generate it this way, but it is not your final product! That will be wherever you chose to save it!
ā2004-10-22 02:32 PM
