Can I get round edges on slabs ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2008-11-09
10:30 PM
2023-05-25
05:51 PM
Rubia Torres
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-10 01:08 AM
and using it to follow a path that is shaped like your handle or
you could use Profiler to do the same thing.
Peter Devlin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-12 10:56 PM
I made a handle with the polyline tool in the floorplan. That also has a cross-section of almost the same size. Then I use the magic wand to apply the wall-settings with the profile to the handle. The handle is not filled but I create some long walls. I suppose I have misunderstood the advice I got. I post the project so you can take a look if you like.
Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-12 11:39 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-13 11:23 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-13 04:15 PM
Draw the
The oval complex profile should be centred on the origin when you set it up for this to work correctly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-13 05:57 PM
and 36 segments is OK.
Peter Devlin
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-13 07:35 PM
(part 1 of 2)...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-13 07:38 PM
ArchiForma lets you do most things that can be done with GDL primitives, such as this rounding. You might be interested in downloading the user manual to see:
And, maybe the demo version will work long enough just to create your handle.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2008-11-13 07:46 PM
To get a complex profile extrusion to "taper" requires wrapping the section back on itself slightly by using a tiny radius.
