Can I turn off the white reference plane in the 3d Window?
Always seems to be in the way of seeing the building...
Awesome.. that's what I needed. Thanks much!
3 Replies 3
You are searching for:
View menu -> editing plane display
David Maudlin
MaxamAC:
Or try Work Environment > User Preference Schemes > On-Screen Options > Display Editing Plane during editing operations only.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Link
If you want to just tone it down a bit, whilst in the 3D window you can go to View>Grid & Editing Plane Options> Grids & Background. From there you can adjust the color and opacity of the background, which is what the editing plane uses.
Link.
