Can SEO be used in complex object???
Hi everyone,
I've a SEO question, is in what condition or element can be use SEO?
I've try subtract a sphere(object) to a slab,it's work but when I try a bottle(object) to cut the slab, it's not work, Is that bottle too complex??
Or Is any way to do if I want a hole cut in slab like bottle mould in slab,
not noly cut bottle shape in slab.
javascript:emoticon(':(') sorry I know I explain not well, but hope you guys
can understand.
THANS A LOT
23 REPLIES 23
Rakela Raul
does SEO work with objects created in MaxonForm??
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
tina_yi
What tool (plug-in) was used for bottle creation?
Matthew Lohden
Some library parts may not be true solids. That could be the case with your bottle.
Ralph Wessel
Mentor
Scrat wrote:
How do you do that?
Just using ArchiCAD's Solid Element Operations (SEOs). The complexity of the bottle object is definitely a factor in the success of this tool. When my bottle object was set very smooth, an attempt to use it as an operator against the slab was unsuccessful. It sat there for a long time (with spinning cursor), and the slab remained unchanged when it finished. Pushing the bottle smoothness down resulted in the image you see and finished reasonably quickly.
Ralph Wessel BArch
Active Thread Ltd
I know how to make object but what was asking is how do you create that ball-shape part (top of the bottle).
And how do you usually create a ball
Ralph Wessel
Mentor
The bottle shapes were made by drawing half their cross-section with the polyline tool and creating a lathe profile with OBJECTiVE. I drew two different profiles because I wasn't sure which case the original question referred to (see the attached image). One profile creates a solid blob, the other is hollow inside (as a real bottle would be). The effect with SEOs is quite different in each case, but the critical step was to make sure the objects weren't too smooth (the SEO would fail).
I create a ball or sphere by just drawing a half-circle and profiling it with OBJECTiVE.
Ralph Wessel BArch
Active Thread Ltd
Hello Ralph,
Would you agree that, in case someone does not have Objective,
the exact same procedure as you describe works with
Archicad's Profiler using the revolve construction method ?
Thanks,
Peter Devlin
Ralph Wessel
Mentor
Peter wrote:
Hello Ralph,
I don't know - I haven't used Profiler for a long time because the objects it produced were a bit crude. I usually want to rotate and/or cut up the objects I make, which I don't believe Profiler supports. OBJECTiVE components also have a built-in smoothness setting.
Ralph Wessel BArch
Active Thread Ltd
Hello Ralph,
You are right Profiler does not support those things except
for resolution of arcs which now can be set in the magic wand settings.
I think this is only true for the resolution of the path but not the
resolution of a shape done with the revolve command.
Your discovery that SEO does not work if the "smoothness",
or as I take it polygon count, is too high is a surprise to me and
my explain why some library parts I have made do not SEO
with anything when used as operators. These parts were made
with the mass command and have high polygon counts.
Thank you for the tip.
Peter Devlin
Hello Ralph,
Sorry I reply late, and thanks ,that's exactly what I want to do,
Now I know the problem is that if I profile the object in solid then I can cut it in slab, right ,
Thank again , you are really genius,javascript:emoticon(':P')
Hello Ralph,
It's me again, I've try to give the bottle thickness but still not work, how do you down the somthness? I go to 3D script to change the resol 36 to 20 , is't the way to do??
Sorry to bother you again.
